How to make a reference spectrum to carry out spectral measurements in ocean optics spectrometer
I have corrected the vi , as you said I have removed every thing and made an empty array with the shift register . Is it the correct way. please guide me if am wrong.
Thanks for replying .
Message 11 of 22
(3,235 Views)
Thanks a lot for the reply .
I want to make the vi similar to the spectra suit .
I will make it clear how i want to make my vi
I want to have integration time , scans to avegrage , scope  options in it .
Then i would like to have remove the dark sectrum and make a reference spectrum to carry out measurements .
Then to measure the most important parameters i.e Absorbance and Transmittance .
This is my aim .
Please help me with this! any example vi will be very help ful
Thanks in Advance
Message 12 of 22
(3,234 Views)
am waiting for help ! anyone there to guide me plz...
I have tried to use array to store the spectrum in an array and subtracted from the (zero) spectrum is it correct way to get the reference line !
Need help!!
Message 13 of 22
(3,212 Views)
Hi tanveer,
what have you tried so far to allow all those requirements from your list?
You surely need a button to allow to store your "dark spectrum"only when the button is pressed.
Then you need a case structure (or Select function) to handle to storing process conditional…
Again: Please attach your code as VI or snippet. We cannot (and don't want to) debug any images…
Message 14 of 22
(3,202 Views)
this is the code which i used to removed dark spectrum with a click ! so that i can have a reference to carry out measurements .
suggest if am wrong !
Message 15 of 22
(3,197 Views)
The spectrum is a 1D array, the background spectrum (in the shift register) should also be a 1D array. Do not store a new background every time, otherwise you will not be able to analyze whatever light source you're looking at.
Message 17 of 22
(3,185 Views)
Accepted by topic author tanveer1993
I've made a little VI you can play with. Light source on and off is just for fun. Pay attention to what happens in the bottom shift regsiter when you click "take background". Then look in the timeout case and note the difference in the "background" vs. "no background" case.
Message 18 of 22
(3,183 Views)
hello ,
Firstly thanks alot for the support with your guidence (specially Gregoryj) i coud make the reference spectrum .(base line correction ).
I have done base line correction , Integration time , Scans to average and
Now the next  task is to make the Absorbance and Transmission measurements  of the sample.
In spectra suit after removing dark spectrum (baseline line correction ), we save the reference spectrum and carry out the absorbance and transmission measurements .
The most important issue is I wanna use the say graph to display all !
So I wanna make the labview software in the similar way.
Message 19 of 22
(3,161 Views)
This smells like homework or an assignment......
Message 20 of 22
(3,152 Views)
