How to open a vi twice and show 2 front panels.
Hello.
I want to put one Sub-VI twice on the block diagram and run them on the same time, showing 2 front panels.
The VI has a while-loop inside, because I want to use the parallel loops paradigm.
It does not work, it only shows 1 front panel at a time.
Is this possible?
The Enrichment Center is required to remind you that you will be baked, and then there will be cake.
(2,567 Views)
Accepted by SectorEffector
Make the VI reentrant (in VI properties)
(2,564 Views)
