How to programmatically get all the list of value names under a key in windows registry?
Hi
How to programmatically get all the list of value names under a key in windows registry without configuring number of values in the key?
Thanks & Regards
Samuel J
(4,602 Views)
Hi Samuel,
you can use the "Enum Registry Keys" function. If you need more than one layer then you can use it recursive.
Mike
(4,600 Views)
Smiley TongueThanks for your reply mike.
But "Enum Registry Keys" will return subkeys not the values, I think you will suggest to use "Enum Registry values simple" instead of that. But there is a input terminal named "value info" to specify number of values in that key.
So my question is how can i get the "value info" info programmatically.
Warm Regards
Samuel J
(4,592 Views)
Accepted by Samuel_James
Hi Samuel,
you'll get this info from "Query Registry Key Info.vi".
Mike
(4,590 Views)
