How to sample data every two points in LabVIEW FPGA
Hello everyone,
Now I want to use the High throughput math function to do calculation. The function I used is Arctan(x/y), which has 2 input ports, x and y. My block diagram as follows:
The data comes is the sampled sine wave data, the sample rate is 4 times of sine wave frequency. So I can get 4 samples every sine wave period, it is called I Q sampling. Let's say the data comes is like 1,2,3,4,1,2,3,4,1,2,3,4..... What I want is either (1,2) or (3,4) as (Y,X), and abandon points (2,3) and (4,1).
As what shown on the picture, I used a feedback node linked to Y as a latency. So in the first cycle, (Y,X) will be (1,2). In the second cycle, (Y,X) will be (2,3). This is not what I want.
So is there any good way to solve this problem?
Thank you.
(4,523 Views)
The simplest solution would be use a case structure so that the math is done every  second cycle.
(4,515 Views)
Could you please explain it more specifically? How to write functions in case structure?
(4,507 Views)
Can't you just toggle the input valid input of your ATN function to control when to perform the operation or not?
(4,465 Views)
Hi, thanks for replying.
I try to do it on the input valid port, but don't have a good way to solve it.. Do you have any good ideas?
(4,448 Views)
I assume you have your channel counter somewhere, maybe counting 0..3 (for channels 1..4). Then you could just extract the lower bit and wire it to input valid. The lower bit will be T if the counter is odd (1, 3).
(4,444 Views)
Accepted by zyb1003
A simple shift register that holds a boolean and you just invert (NOT) each iteration would do the job.
(4,432 Views)
