How to send SMS from 3g modem through labview
My project is to build a sms sending application from labview through a 3g modem. I have bought a d-link 3g modem(DWM-156), my modem is installed as a CD drive in my system.
I am new to this interface. Please let me know how to connect both the things.
Thanks in advance,
Vignesh ramesh
(3,331 Views)
Hi Vignesh,
Might be you can call ActiveX or DLL objects of the software installed for modem from LabVIEW, if it is unblocked.
Have a  look on the link > http://zone.ni.com/devzone/cda/tut/p/id/2983
(3,317 Views)
It installed as a CD drive? That makes no sense. Are you sure it installed properly?
There have been previous posts on sending SMS. Did you try a search?
(3,311 Views)
Hi Puneet,
Thanks for the reply,
I found that there are dll available for dlink software. but i do not no the parameter to communicate to it through labview.
Vignesh
(3,287 Views)
Hi Vignesh,
May be in Dlink user manual have some description of the DLL methods, otherwise you have to apply hit and trial method.
(3,285 Views)
