How to separate and group string?
I'm working on a radar project, and propose to receive two types of signal in labview through serial port.
The receiving signal is like:
I350
Q350
I250
Q150
IXXX
QXXX
one signal with header I, the other one with header Q, my question is how can I group string with header I together in one array, and group string with header Q in another array?
Message 1 of 21
(4,461 Views)
Hi yatang,
Are you using LabVIEW 2012 or later? If so, I believe this code should work for you.
Just use String Subset to extract the first letter, then compare it with I and Q, and finally, use the auto-indexing with conditional tunnel to separate out signals that starts with I and starts with Q.
Link about auto-indexing with conditional tunnel: https://www.ni.com/docs/en-US/bundle/labview/page/conditionally-writing-values-to-loop-output-tunnel...
Hope this will be helpful.
-Ee Lim-
See that button on the left side of this post...
If you feel my post is helpful, all you need is just (at most) 2 seconds to click that button, to show your appreciation. Thank you~~
Message 2 of 21
(4,442 Views)
Fantastic!! Thank you very much!! I'll try this method!!
Message 3 of 21
(4,388 Views)
If course if you want to do it a bit faster than that.Smiley Wink
Smiley Wink
Message 4 of 21
(4,374 Views)
I have a strong suspicion that the Search 1D Array is not doing what Jeff thinks it is doing.
Message 5 of 21
(4,358 Views)
Yes, that should be find first match!  (Not my day)
Message 6 of 21
(4,353 Views)
Thank you! And  I have another question, please have a look on this code, I tried two ways to display the graph after FFT, but there's no graph displayed T_T
Message 7 of 21
(4,344 Views)
That would be becaues you a feeding an array of size 1 into the FFT
(Get rid of those DDTs- they are only letting you mis-wire your data.
Message 8 of 21
(4,336 Views)
OK, so I should build a array, thank you!
Message 9 of 21
(4,323 Views)
one more question please, how can I do it inside the loop?
Message 10 of 21
(4,322 Views)
