How to set text to be transparent to clicks?
Originating Need
I have the desire to have an LED-button on the Front Panel (FP) which is used as a Button. I would like to add white-text over the top of it as a label (e.g. 'Skip' or 'Run')
Current Issue
When a text Label is added on the FP over the top of the LED ('Reorder->Move To Front') you can't click on the LED through the text 😞
Question
Is there a way to make the full region of the LED clickable here, specifically the region behind the white-text label?
If there is, that would be sooooo rad 😉
-Justin
justinmreina@gmail.com
(3,995 Views)
You can have Boolean Text shown. Right-click the LED and go to Visible Items > Boolean Text
FYI, careful with having your email address in your signature. There are bots that scour forums like this for email addresses to sell.
Cheers
(3,990 Views)
you can programically change "text" and "color" or make it "transparent" with property node
(3,971 Views)
Accepted by Justin_Reina
I think OP didn't know that boolean text was an option. He was having problems with a text label he made separately and put over the button and it blocked clicking.
In the below FP boolean, I can click the "OFF" just fine to control the button, but the other text blocks:
Cheers
(3,958 Views)
Hi James  & apok,
 Thank you!!! I compiled your responses into a tabbed example VI, for others who may someday stumble upon this now silly question.
Thanks!
*I couldn't attach the VI for some reason... it was rejected on 'file-format'. So I just zipped it up and it magically posted 😉
(3,888 Views)
