How to set the tabulator order for the cells in one table?
Is it possible in an easy or short way to change the order of the tabulator jumps in one table? So that first all cells in one row and then all in the next column are active or otherwise.
(2,701 Views)
Accepted by topic author Lindemann
Hi Herr Lindemann,
the (rather) easy way would be to use an event structure to capture "tab" keypresses and to set the active cell using property nodes...
(2,689 Views)
Thank you for the fast reply. I thought this would be the solution, but i hoped there is an easier way. 😉
(2,686 Views)
