How to show the value and the color simultaneously in an intensity graph
Hi, Friend:
I'm working on mapping program by labview, and close to finish it. However, I faced a small problem while I'm using the intensity graph. As we know, the intensity graph uses the color to represent the value of z axis. What I want to do is to show both the value and color in the same graph. My design is similar to the attached pic. In the left, I have the data; whereas in the right, I plot the graph. I just want to show them together, could I?
Thank you very much.
(3,069 Views)
Accepted by colorizedice
Topic is already being discussed here
(3,061 Views)
Thank you very much!
(3,053 Views)
