How to split the string????
Thank you very much for your answer.
I have one sensor named hagisonic Stargazer And I want to read the output string.
And that string has ~^| 123 |-22.22|+223.|1234
I want to read the value after | sign.
Greetings,
Ankit.
Message 11 of 19
(1,847 Views)
You've been given a couple of solutions. What is the problem with them? Show what you have tried.
Message 12 of 19
(1,842 Views)
I guess he wants to get all numbers and their signs (-/+) and removing all other symbols (~ , ^ , | etc etc)
regards,
yan
Message 13 of 19
(1,838 Views)
Hi yan,
and where's the problem with all the solutions already provided?
Ankit gets all numbers…
Message 14 of 19
(1,833 Views)
AnkitRamani wrote:I want to read the value after | sign.
Search/Split String will be your friend here.
Message 15 of 19
(1,832 Views)
Perhaps a program to read and split different input strings, which is changing everytime.
regards,
Yan.
Message 16 of 19
(1,823 Views)
Thank you very much for your reply.
I am getting the result form previous suggesting, but the thing is that I don't want to get the symbol in first reading that are
'' ~^ '', and if possible then I want to read the value not in Array form only but I want to read that in element form i.e.. Array to elements.
Here in attachment I have attached the example vi for same thing which I am doing.
But I think may be i will solve this problem by your suggesions.
Thank you verymuch for your help again.
Greetings,
Ankit.
Message 17 of 19
(1,817 Views)
Sounds like my Scan From String method is what you really want then.
Message 18 of 19
(1,806 Views)
Hi Ankit,
You have been shown to use the IndexArray function. What's the problem with our suggestions?
Message 19 of 19
(1,782 Views)
