How to use GPS to synchronize measurement at 2 different locations.
In the 1st fig, the Trimble box offer an 10MHz output to the 6682 at right.
But I remember the 6682 has an 10MHz output itself.
Any suggestion? Thanks.
Message 21 of 24
(850 Views)
Hi jmaczak,
Sorry to disturb you. i'm new to the GPS. Now i have the same issue. i want to use GPS to synchronize measurements from 2 different sites. so you mean i have to use the DAQ  to realise this? and how to configure the TTL PPS signal as a trigger source?
Regards
Henry
Message 22 of 24
(700 Views)
Hi jmaczak,
sorry, i just realised the measurement in my case was done by the CRIO. my question is how can i use GPS to make sure both CRIOs start to measure the voltage at the same time?
Regards
Henry
Message 23 of 24
(699 Views)
Hi Matt,
I'm looking for (and not finding) a copy of the bc635 PCIe labview code. All the microsemi has is a 5.1 version that I can't load.
Do you have this in any of the more recent versions of labview? Say 2009-2013?
Message 24 of 24
(627 Views)
