How to use a vi on the ipad using the data dashboard app.
I am trying to use the data dashboard application for iPad, to run a simple vi, and I cant figure it out.
Any help would be great.
Kevin
(2,857 Views)
Hi Kevin,
Are you using a VI created in the LabVIEW Development System? Data Dashboard only allows you to connect, control, and view variables and web services you have running on other systems. So you can read from and write to shared variables hosted by LabVIEW on your development PC, but you cannot directly program in Data Dashboard.
You can find the Getting Started with Data Dashbiard tutorial at this link.
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
(2,821 Views)
Hello!
I strongly recommend you to take a look at this document > http://www.ni.com/white-paper/13757/en
It may solve your problems (as it solved mine).
Hope this helps! Smiley Wink
(EDIT: Well, I didn't see the answer above. Sorry for duplicate post)
Joao Paulo Mondoni
Quarcum Technologies
Mondoni
(2,810 Views)
