03-25-2013 06:35 PM - edited 03-25-2013 06:39 PM
I am trying to use the data dashboard application for iPad, to run a simple vi, and I cant figure it out.
Any help would be great.
Kevin
03-26-2013
10:52 AM
- last edited on
10-12-2025
03:33 PM
by
Content Cleaner
Hi Kevin,
Are you using a VI created in the LabVIEW Development System? Data Dashboard only allows you to connect, control, and view variables and web services you have running on other systems. So you can read from and write to shared variables hosted by LabVIEW on your development PC, but you cannot directly program in Data Dashboard.
You can find the Getting Started with Data Dashbiard tutorial at this link.
12:46 PM
- last edited on
10-12-2025
03:33 PM
by
Content Cleaner
Hello!
I strongly recommend you to take a look at this document > http://www.ni.com/white-paper/13757/en
It may solve your problems (as it solved mine).
Hope this helps! ![]()
(EDIT: Well, I didn't see the answer above. Sorry for duplicate post)
Joao Paulo Mondoni
Quarcum Technologies
