How to use same object in another vi file.
Hi i am new to OOP in labview.
How to use (ACCESS) same Object in multiple VI fiels in labview.
in c# if we use same name space , then we can acces the object .
i dont know how to use it in labview.
and also i need to know , how to use oop in large applications
Message 1 of 19
(5,011 Views)
I'm not sure what you mean. Can you explain exactly what you want to do?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 19
(4,988 Views)
hI Mike,
THANKS FOR YOUR RESPOMSE ,
I AM NEW TO LABVIEW OOP CONCEPT,
1.I HAVE ONE  COM port Reading Class ,
2. from that class i am creating 2 objects (COM 1 , COM2) . in main VI ,.
How to Access that objects COM1 AND COM2 in sub vi files ?
Message 3 of 19
(4,904 Views)
You could just pass the objects into the subVIs via the connector pane and wires, just like any other data.
Message 4 of 19
(4,845 Views)
Exactly, there is no magic here.
Object = Wire
Mike...
LabVIEW Champion
Message 5 of 19
(4,820 Views)
Thanks for the answer ,
Please give some Eample file ..
like OOP
Main vi creates the objects,
and subvi calling the same object and modifying .
I mean OOP + MAIN VI + SUBVI
Message 6 of 19
(4,750 Views)
There is nothing to demonstrate. A LabVIEW object is just another kind of wire and you pass it around your program like you would any other wire. Nothing special to see.
Mike...
LabVIEW Champion
Message 7 of 19
(4,720 Views)
LVOOP EXAMPLE HERE
Cheers
Message 8 of 19
(4,700 Views)
Mike thanks for the reply,,
James.Morris thanks for the example.
after seeing example ,
i have another question.
whats the difference betweent LVOOP AND ACTOR FRAMEWORK.?
Message 9 of 19
(4,673 Views)
Oh boy...
Actor Framework uses LVOOP, they are not two different things, just one inside the other.
You need to do some of your own research to get your head around it.
To be honest, it sounds like you are new to LabVIEW, so maybe you should start off with basic LabVIEW programming practices before moving up to LVOOP and Actor Framework.
Cheers
Message 10 of 19
(4,668 Views)
