How to use same object in another vi file.
Actor framework is a way of easily generating large cumbersome applications that exhibit all sorts of bizarre behavior.
Mike..
Elephant: el-e-phant
noun
1. The largest living land animal
2. Mouse built using the actor framework.
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 19
(4,541 Views)
Well LVOOP tries to be this...
And the Actor Framework tries to be this... Using some of LabVIEW's object oriented components.
You can have LVOOP without Actor Framework, but you can't have the Actor Framework without LVOOP.  You can however have other actor based designs without LVOOP but honestly few go this route because classes help force the developer to work inside the constructs of the design.
Also quit yelling so much.  And before you try taking on LabVIEW's object oriented designs (and Actor for crying out loud) I'd suggest taking some beginner training which can be found at the bottom of this page.
https://forums.ni.com/t5/Community-Documents/Unofficial-Forum-Rules-and-Guidelines/ta-p/3536495
Message 12 of 19
(4,539 Views)
Yes i am new to labview . but this is the first time i am studying about LVOOP,
Anyway thanks all for the Reply
Message 13 of 19
(4,505 Views)
So you're learning how to drive a dragster before you know what a steering wheel is?
Bill
CLD
(Mid-Level minion.)
Message 14 of 19
(4,484 Views)
Hi James,
Thanks for the Kind advice:-)
Message 15 of 19
(3,947 Views)
WOW.  That's a late reply.
Message 16 of 19
(3,930 Views)
Haha, indeed
Cheers
Message 17 of 19
(3,926 Views)
Maybe it took him 3 years to learn how to drive.
Message 18 of 19
(3,921 Views)
Lol
Message 19 of 19
(3,910 Views)
