How to use z800 3d visor in the labview?
Can anyone help me how to connect a head mounted device(z800 3d visor) in the labview?
I am using a camera and want to display the image output in labview to the head mounted device.
Thank you in advance.
(2,807 Views)
You probably need something like this: http://zone.ni.com/devzone/cda/epd/p/id/5030
A good place to start may be: https://forums.ni.com/t5/LabVIEW/Using-a-Webcam-with-Labview-8v5/td-p/612535
This has some good links.
Haven't ever tried this, but good luck.
(2,804 Views)
Thank you so much g_e_m_i_n_i.
I am able to use NI vision module for the integration of camera. Can you give me any solution like if i want to show the output from the camera -> labview and that output to any external devices??
(2,800 Views)
