How to write image to xlsx
I have been able to write data to a csv with the write to spreadsheet vi, but that only allows me to write text to a cell, I am now trying to use the vision development module, and I need to place the image that I will analyze in a cell of the spreadsheet in a xlsx, instead of a csv.
I know that there is an xlsx addon in the VI Package Manager, but I am not quite sure if I can write images to the spreadsheet, as I would if it was a line of text. The addon I installed is called CLAUDIE_xlsx.
What I wish to do is add the image in a build array and build my table from there.
Can someone please give me some advice on how I can do this?
Thanks in advance.
(2,678 Views)
Accepted by Nando88
It seems that the add-on can only write strings to an xlsx file, so I found a workaround. All that would be needed is to write the paths of the images in a column, and then run a vba script I found here:
 https://www.extendoffice.com/documents/excel/5046-excel-display-image-from-file-path.html, to convert the paths to images.
(2,645 Views)
Hi Nando,
have you tried to use the RGT (ReportGenerationToolkit), that comes with LabVIEW?
It's made to create documents using MSOffice software remotely…
(2,604 Views)
