Hyper terminal Launching from labview
Dennis and Marc , Thank you for the advises. I am attaching a screen shot of the running VI. I have added on my VI the Write Function, Termination Char Control. I also made the String Control in Code Display. I ran this VI and log "c?<CR> on the String Control, but it looks it is ignoring my command. Normally if I log "c?" it should answer back like c: 180, this is the azimuth value. But it now shows a complete NMEA sentence data. I have placed <CR> as per instruction on the manual (pages 3 to 5).
Kindly teach me what I am missing. Thanks a lot.
Message 11 of 33
(3,560 Views)
Hi Dennis and Marc,
Its now workingSmiley Happy. The Basic Serial Write and Read shipped with 8.2 was a good example for me. I can now communicate to the sensor directly. Thank you very much for the lots of advises. Please ignore my earlier post.
Bong
Message 12 of 33
(3,559 Views)
Marc A, can you give me the vi?
I have the same problem
Message 13 of 33
(3,029 Views)
I programmed an easy terminal programm already, if you want, you can download them here:
http://www.labviewtutorial.eu/viewtopic.php?f=18&t=133
Eugen
Message 14 of 33
(3,025 Views)
Message 15 of 33
(2,763 Views)
In Hyper Terminal you can insert a delay after each char xmitted. This is avail from File->Properties->Settings->ASCII Setup and then insert the mS at the char delay box. How can I do it in Labview? I have tried the various Timing functions and scoping the xmit line I do not see the forced delay in the stream.
Thanks!
Message 16 of 33
(1,816 Views)
You have to code it yourself. An example is here.
Message 17 of 33
(1,814 Views)
Hi Dennis
I am facing with simple problem, please suggest me .
I want to achive the connection between a "VI" as server and the "HYPERTERMINAL" as client  for TCP/IP communication. I am not able to connect hyperterminal to VI server. can any point out on wht i need to concentrate.
But I can do connection btwn 2 VI's acting as server and client. All kinds of suggestions are appreciated.
Message 18 of 33
(1,581 Views)
Why hyperterminal? The tcp/ip or VISA functions will work. Have you tried any of the shipping examples?
Message 19 of 33
(1,578 Views)
Thanks for the response
Actually my application demands this....
I need to aquire the data from microcontroller to my server VI.This has to be done using TCP/IP communication using GPRS .
My AT+usoco=2,"IP ADDRESS",PORT NUMBER, command is not working. its giving error.
can u plz suggest where i am going wrong or any other way i can go with,to achieve my application???Smiley Sad
Message 20 of 33
(1,573 Views)
