Hyper terminal Launching from labview
Why do you need Hyperterminal to do this?  I have a feeling all it is doing is getting in the way.
Bill
CLD
(Mid-Level minion.)
Message 21 of 33
(1,232 Views)
I really have a hard time believing that your application demands hyperterminal. You have not attached any code so it is impossible to say what you have done wrong.
Since hyperterminal no longer shops with Windows and it does not have a programmatic interface, you are just painting yourself in a corner by insisting on using it.
Message 22 of 33
(1,229 Views)
Good Morning Dennis
Yes, offcourse my application does not require hyperterminal.Instead of Microcontroller code, for tcp trail i am using hyperterminal.
I am attaching a sample Vi with which I tried doing the connection from hyperterminal.The first question of mine is , Can a hyperterminal talk with VIs.???
If so, then how i should proceed.???
Vi is in 2013 version.
Message 23 of 33
(1,209 Views)
Why don't you try the built-in functions instead? You keep approaching this from the most difficult way.
Message 24 of 33
(1,206 Views)
Built in functions mean.... you are trying to tell to use the tcp functions in client also,instead of hyperterminal!!!
Message 25 of 33
(1,199 Views)
hello billko
I mentioned my process and attached vi i am using. can u please suggest for my process!!!
Message 26 of 33
(1,192 Views)
Everyone is suggesting that you use the LabVIEW tcp/ip functions instead of hyperterminal. You said you don't require hyperterminal so don't use it.
Message 27 of 33
(1,187 Views)
Okay,Okay.Fine then thank you Dennis. I will then try making communication with controller and the labview VI only directly.
But I am curious that why I met failure for using hyperterminal!!! What might be the reason Dennis?
Message 28 of 33
(1,184 Views)
Sorry, no clue. I haven't had Windows XP and hyperterminal in years.
Message 29 of 33
(1,176 Views)
Fine . Thats okay. No probs. Thanks for your time and solution dennis. Smiley Happy
Message 30 of 33
(1,172 Views)
