I can not find virtual bench library
Hello All,
I am trying to run virtual bench from labview but I cannot find the vi package to install.
Please help
Thanks!
Gil,
Message 1 of 11
(4,029 Views)
Accepted by gilmaor1
What version of LabVIEW are you using?  The latest version of the VirtualBench Software is currently 2019, which will not work for LabVIEW 2020.
GCentral
Message 2 of 11
(3,994 Views)
You are right. I tried it on labview 2020.
working on labview 2018.
Thank!
Message 3 of 11
(3,976 Views)
Hey Guys,
I have the same Problem and couldn´t find any Solution.
How could you downgrade your Labview version?
Or where can i get an old Version of Labview?
Even any advise that could help me is appreciated.
Thanks for help, your gotti
Message 4 of 11
(3,924 Views)
Hey Guys,
i already read in the forum that until now there is only a Virtual Bench Support for Labview 2019.
Is there any possibility to run it on 2020 or do you have any advise to fix the problem?
Already tried Bench 18 for Labview 19 with the 19 Version, but it didn´t work.
I appreciate all kind of help.
Your Gotti
Message 5 of 11
(3,927 Views)
Thanks!
Tested and working on 2018 ver.
Message 6 of 11
(3,905 Views)
Hey gilmaor,
where did you get Labview 2018?
Seems like the only Solution to work is with an old software, didn´t expect that by such an expensive Hardware.
Greetings Gotti
Message 7 of 11
(3,899 Views)
LabVIEW Download
There is a drop down to choose which version of LabVIEW to install.
And for completeness' sake: VirtualBench Software Download
GCentral
Message 8 of 11
(3,894 Views)
Just for reference. It is possible to get the VirtualBench working in newer versions of LabVIEW.
Instructions here.
I have tested it myself in 2020 and am about to do it (again) for 2022.
Message 9 of 11
(3,499 Views)
It's a shame the VirtualBench is actually called out here to not be updated to use the new (as of LabVIEW 2022 Q3) Addon folder.  Considering the items it is listed with, I am left to think that NI is set to stop selling the VirtualBench.  But my VB-8012 does show up as a ADP5250 in Digilent Waveforms, so I'm going to start porting my VirtualBench code to use that instead.
GCentral
Message 10 of 11
(3,488 Views)
