Hello.
My system is a ni pxi 8106 RT with labview real time software embedded in a chassis pxi 1042.
I have put into 2 cards:
1) ni pxi-5102 digitizer
2) ni pxi-7831R FPGA
When I open Max everything looks ok, I have the system in my subnet and I see it and the cards installed.
I have also installed all the RT software on the target.
The problems are 2:
1)From max if I double click on the pxi5102 I can see only the information but I don't see channels(that should be 2). I tryed from data neighborhood to set an analog input but it says no supported device found.
2)When I try to open the visa test panel test says that the access to the remote machine is denied because of insufficient privilege.
Do I have incompatibility problems?
Did I missing some settings?
thanks a lot!!
Ciao
Mario
