I cannot install the NI-RIO driver in my cRIO using MAX 5.5
I can connect it assigning a static IP. Whenever I try to install the software in the FPGA Target, appears the following error:
"Timed out while communicating with remote target. Ensure that the system is online"
What can I do?
I have LabVIEW 2013 installed in WINDOWS 8
Message 1 of 9
(3,919 Views)
Its possible something is out of sync.  Try deleting the system from MAX.  Then close and reopen MAX.  Expand remote systems and try again.  If that doesn't work you may wand to try and format the target.
Message 2 of 9
(3,911 Views)
I made it all. The connection is OK, but whenever I try to install the RIO driver, it doesn't work. It takes a long time to appear the error
Message 3 of 9
(3,901 Views)
How fast is your network?  Are you connecting over wireless or VPN?  Its possible the FTP operation is timing out because the network is just too slow.
IF your network is really slow you could try to bump up the MAX timeout by modifying the Windows registry.  See this KB (http://digital.ni.com/public.nsf/allkb/34B6BA46CBCFAF088625728800770071) for details.
Note if you are running a 64-bit version of Windows the path in the registry will need to be HKEY_CURRENT_USER\Software\Wow6432Note\National Instruments\Measurement & Automation Explorer\Remote instead of what is listed in the KB.
Message 4 of 9
(3,889 Views)
OK, I'll try it.
But I'm connecting my cRIO directly to my host computer (Windows 8 64-bits). Before the LabVIEW 2013 installation my cRIO was working very well without problems. Once I installed the MAX 5.5 this trouble started (although I have LabVIEW 2012 installed).
I had to uninstall the cRIO in order to show a student how to configure the cRIO from zero, but finally I couldn't.
On the other hand, the cRIO connections doesn´t last a lot. Only appears when I try to install the softwar in the FPGA target.
I apologize for my poor English
Message 5 of 9
(3,881 Views)
If you have a direct connection, it is unlikely a network slowness issue unless Windows 8 is doing something weird.  Have you tried to install anything other than NI-RIO? Can you install just LabVIEW RT or NI-VISA?
Also, in your original post you mentioned the target had a static IP address.  Have you verified that you can ping the IP address from the command prompt or manually FTP files to it?  In order for MAX to install software the target and the host need to have a routable IP address.
Message 6 of 9
(3,879 Views)
My big mistake was to upgrade to LabVIEW 2013. With 2012 all was great.
Message 7 of 9
(3,871 Views)
Accepted by vitrion
Hi Vitrion,
As we see in the Service request this problem was solved when you downgraded to LabView 2012 and resintalling Max5.5, so we could install correctly the NI-Rio Driver and see the device in MAX. Apparently it was a compatibility problem in versions...
Just a recommendation for cases just like this one. We have to check the compatibility chart before installing a LabView update in order to have the correct version in NI-Rio Driver.
http://digital.ni.com/public.nsf/allkb/577CC9A7DCFC73DF8625738400116CC3
Omar I.
Applications Engineer
Message 8 of 9
(3,840 Views)
OK thank you
Message 9 of 9
(3,833 Views)
