I have a LAbview 8.6, and i can´t open a file from a Labview 5.1.1
             When i try to open a file(a driver to an OSA from Agilent) appears a error message, saying that the source´s version is too old(5.1.1), when my labview is 8.6.
             Anybody knows something about it?
             Thanks a lot.
Message 1 of 19
(4,899 Views)
Hi.
I managed to see old vi's made in version 4 with 8.5
First opened with Labview 8.20, saved for previous versions 8.0
Then opened with Labview 8.5..voila
I have Labview 4,  8.20,  8.5,  on different computers.
Message 2 of 19
(4,894 Views)
Accepted by carlosmayer
Hi Carlos,
as told before (and in numerous other threads too) LV8.6 can only open vi from LV6 and up... So you need an older LV version to convert (very) old vis.
I attached the LV8.0 version. There's a missing dll - I hope you have it on your harddisc.
When you look for device drivers it is always a good idea to check the NI website for them...
Message 3 of 19
(4,875 Views)
              Thank you very much, it will be very useful.
               It worked perfectly.
              Thanks a lot!!!
              and the .dll file was already in my computer.
Message 4 of 19
(4,860 Views)
oh and thanks for the clues about drivers also,
i have done a simple interface for a multimeter, and now the goal is to do one for the OSA,that must be much more difficult....rs
Carlos Mayer
Message 5 of 19
(4,853 Views)
Then mark Gerd's message (#3) as the solution to your question and not your reply #4 where you are thanking him.  You didn't solve your own problem!  Unmark #4 as the solution and mark #3.
Message 6 of 19
(4,827 Views)
                         Hello again.
                        Sorry for marking the wrong post, but i don´t know how to change it.
                        By the way, I am with the same problem again. If anybody has time and a version of Labview able to do this, I would be very grateful. The link is below.
                        Thanks, Carlos Mayer
Message 7 of 19
(4,663 Views)
Please click on "options" located on right top corner of your post where you marked solution and select "unmark" from the menu. Then please click on the "options" located on right top corner of the post which you think is the best solution for your problem and select "Mark this as solution".
Mathan
Message 8 of 19
(4,655 Views)
The manufacturer's web site has a newer version of the driver for that instrument. It's not written all that well, but at least it uses VISA, unlike the VI you uploaded, which uses old GPIB functions. The library the manufacturer provides is in 5.1, which unfortunately you still cannot open in 8.6. Attached is the library in 8.2. For what it's worth, the VI you uploaded in 8.2 is also attached.
Message 9 of 19
(4,630 Views)
                               Thank you for the help.
                               Yes, I agree with you, these VI´s are a little bit old.
                               But the library,like the other VI, are written to GPÌB connection, and I am trying USB connection.
                               So, by the way, if you have some experience on it, and could give some tip, I would be very grateful.
                               Thanks for updating again,
                                Carlos Mayer.
Message 10 of 19
(4,610 Views)
