I have installed Switch Exec 2.1, running LabVIEW 8.2 and none of the VI's appear on my functions palette
See Subject Line.
Chris
One should welcome adversity as an opportunity to excel.
(2,800 Views)
Hello Chris,
I see that you are trying to get Switch Executive working in LabVIEW 8.2. Here are a couple of things that you should check:
1) Check in the C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\SwitchExecutive directory and make sure you have the nise.llb and niseCfg.llb
    a) If these .llb files are not there, check to see if Switch Executive has installed correctly. You can go into Measurement and Automation Explorer(MAX) to
2) Have you activated your Switch Executive software?
If you have already activated the software and do not see the files there, try repairing the software. Another thing you can try is uninstalling and then reinstalling the software. For the vis to appear in LabVIEW they need to install into that folder. If you find them somewhere else on your system, you can try copying them to that folder.
Please give these suggestions a try. Keep us posted on how that works out for you.
  Sandra T.
Applications Engineer | National Instruments
(2,786 Views)
