I need a DAQ which support 4-20 mA signals
Thanks a lot, Would you please explain how could I wire sensors to DAQ with 500 ohm resistor?
Message 11 of 26
(5,538 Views)
Put the 500 ohm resistor between the voltage input channel of the Daq device and its ground.  You've now created a current loop, and the DAQ device will be measuring the voltage drop across the 500 ohm resistor.
Message 12 of 26
(5,533 Views)
Doesn't warming the resistor because of the current loop, change its resistance and consequently changes its voltage?
Message 13 of 26
(5,530 Views)
Accepted by loghmani
Only if you pick a resistance value that would cause a large voltage drop, and consequently a large power dissipation. Remember P=I*V=I*I*R. More power, more heat. If your resistor is small enough, with the low current you have you should not see an appreciable temperature delta.
Message 14 of 26
(5,520 Views)
Note that the 9219 is a 24 bit and 6009 is a 12 bit...that's quite a difference in resolution....  if 12 bit is satisfactory then go with it...
in my first answer I pointed to a good one at 16 bits, which I am using, 9265, which is about 300 euros. the voltage drop measurement is also a good alternative... it depends on your requirements, all these are listed on ni.com
Message 15 of 26
(5,511 Views)
9265 has no input channel. It is for analog output.
Message 16 of 26
(5,491 Views)
right, it's 9203 which has 8 inputs, 16 bits
Message 17 of 26
(5,470 Views)
I am new to data acquisiton and to this forum so forgive me for the stupid question:
I have a NI SCXI-1121 4-Channel Isolation Amplifier With Excitation but how do I use it for 4-20mA current measurement?
Message 18 of 26
(5,373 Views)
Hi rocinant,
You have to use the SCXI-1338 terminal block to acquire 4-20 mA measurements with the SCXI-1121.
Peter W.
Message 19 of 26
(5,346 Views)
Thanks, Peter. I will actually use the 1120 card. So here is another trivial question, if I may: How do I configure this card and my PCI-M10-16XE-10 for this current input on up to 4 channels?
Message 20 of 26
(5,338 Views)
