I need a portable daq that can measure up to 15 thermocouples that is usb
Hello, a friend of mine that has no experience with labview is asking me about what daq can he buy in order to have a portable thermocouple measuring system.  It has to be usb so he can take it along with him and his laptop and that he can connect up to 15 thermocouples.  I saw some usb based systems that are specificly for thermocuple measurement but only have 4 inputs.  Is there any usb daq that I could use for this application and do I have to additionaly cancel any unwanted noise via programming???
(2,929 Views)
Accepted by hectorh83
Take a look at Measurement Computing which is a part of National Instruments.  The USB-TC has 8 channels, so 2 of those would do the job.
(2,916 Views)
Hi, Indeed there's only a usb up to 4 channels to manage termocouples, this is the NI USB-9211A. But I can suggest you something else:
1. You can buy a SCXI chassis and the Control Module USB NI-SCXI-1600. And using a module SCXI-1102 you can handle up to 32 thermocouples. These are the links:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14235
http://www.ni.com/pdf/products/us/4scxisc278_ETC_196.pdf
2. Another PAC you can use is CompactDAQ along 4 modules NI 9211 (4 thermocouples each one)
http://www.ni.com/dataacquisition/compactdaq/
http://sine.ni.com/nips/cds/view/p/lang/en/nid/14165
3. And one more solution, probably the cheapest. You can buy any USB M-Series DAQ card for example, NI USB-6251 with the SCB-68 terminal block. You can connect your 15 thermocouples to the analog inputs and use the cold-junction compensation built in the terminal block.
I hope you'll find useful this information.
Best regards.
Arturo Gómez | Applications Engineering
Certified LabVIEW Associated Developer
National Instruments Latin America
01-800-010-0793
ni.com/support
(2,892 Views)
I actually have one of the USB-TC's that Raven's fan was talking about.
Works great, and it is USB compatable.
It comes with its own data aquisition software, but whats the fun in that? :smileywink:
Cory K
(2,884 Views)
Thank you very much for the info, I think we will go for the Measurement Computing Option.  It's the cheapest for what were looking for.  Thanks.
(2,843 Views)
