I need to rotate a string indicator 90 degrees. Is this possible
Message 11 of 13
(1,702 Views)
Don' forget that you can only change the caption dynamically, you have to create it manually first even if it is a simple space.
Message 12 of 13
(1,692 Views)
Since you have moral objection to using a caption as an indicator, allow me to horrify you even more:
I sometimes use screwdrivers for tasks other than driving screws (e.g. prying things open).
And I sometimes set items on things that aren't shelves.
Message 13 of 13
(1,660 Views)
