I see the invalid properties.
Hi
I work with DSC.
I created the project with bottoms.
Then I created the Domen and set the in Security Page bottoms the "Disabled & Grayed Out".
Then I Run not VI.
The bottoms are  the Disabled & Grayed Out.
But  the properties "Disabled" of the Bottoms is Enabled.
Why?
Respect
Iskander
Message 1 of 22
(4,341 Views)
What is bottoms and what does it even means -Then I Run not VI.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 22
(4,316 Views)
@Iskander wrote:
Hi
I work with DSC.
Then I Run not VI.
Why?
Respect
Iskander
You should try posting in your native tongue - you'd be surprised at the language support here!  🙂
Bill
CLD
(Mid-Level minion.)
Message 3 of 22
(4,293 Views)
Bottoms=Buttons?
Message 4 of 22
(4,289 Views)
Hi all Thanks for the answer Excuse me for the errors. "I created the project with buttons. Then I created the Domen and set the in Security Page property for buttons the "Disabled & Grayed Out". Then I ran this VI. After I read the property of the buttons. The property the Buttons is Enabled. Why? If I set property - the "Disabled & Grayed Out". Iskander
Message 5 of 22
(4,262 Views)
What is "Domen"?
What version of LabVIEW are you using?
Can you attach your VI?
I remember there was an error in one of the LabVIEW versions several years ago where the descriptions in Help for the enabled, disabled, and disabled and greyed were in error from what the values really should have been.
Message 6 of 22
(4,242 Views)
I have LV 2012
Excuse me.
I meaned Domain.
if I set properties in Domain I want to read this properties in VI.
I set "Boolean 1" - Disabled" in Domain.
When I ran the VI I read the "Enable".
Respect.
Password Domain is 2013.
Message 7 of 22
(4,198 Views)
Message 8 of 22
(4,195 Views)
Message 9 of 22
(4,192 Views)
domain i.e. block diagram?
--Ranjeet
Message 10 of 22
(4,189 Views)
