I see the invalid properties.
Hi
I created my question in 2011.
regards
Isksnder
Message 21 of 22
(390 Views)
Hi Iskander
I downloaded the code but I do not understand your application or what are you trying to do, it will be better as Ranjeet_Singh said “State what problem you are facing i.e. what is expected and what is actual in you VI which you are going to upload”
In the VI I notice that the login VI is not wired to anything  and the while loop will be executed at the same time in other words the login window is not doing anything.
Regards
Esteban R.
Message 22 of 22
(372 Views)
