I see the invalid properties.
Go to properties of boolean and change it. Using property node I read same value.
Attached image file for reference
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 22
(1,343 Views)
Message 12 of 22
(1,339 Views)
It seems that you are having difficulty posting in English, which in turn, is hampering our ability to help you.  You really should try posting in your native language.  I'm pretty sure you can get some excellent help then.  🙂
Bill
CLD
(Mid-Level minion.)
Message 13 of 22
(1,317 Views)
Or he can select the community
--Ranjeet
Message 14 of 22
(1,301 Views)
Hi
Thanks all.
I put the button in the VI.
Then I opened the properties of the button in the Security and the group "Operators" set "Disable & Grayed Out".
I Added to the group "Operators" client "AA".
Then I run the program.
Entered under the name of AA.
Button is in the "Disable & Grayed".
But the  "Properties" show "Enabled".
Why the "Properties" is "Enabled" if I set its "Disable & Grayed Out"?
Respect
Iskander
Message 15 of 22
(1,257 Views)
Which labview you are using? Attach your latest code with 2011 compatible. State what problem you are facing i.e. what is expected and what is actual in you VI which you are going to upload
--Ranjeet
Message 16 of 22
(1,253 Views)
Sorry
I can't to add Attachment
I try from another computer
Regards
Iskander
Message 17 of 22
(1,241 Views)
Hi
Message 18 of 22
(1,224 Views)
Hi
Thanks all
I created the Domain.
Passwords for Domain - 2013.
Then Created Username "AA".
Passwords for Username 11.
For Knopka I created  in "Properties/Security" users "AA" with ACL "Disable & Grayed Out".
When I run this VI I  see  "Properties  of Knopka" - Enable
Why ?
Respect
Iskander
Message 19 of 22
(1,202 Views)
Hi Ranjeet Singh
Knight Rider.
I sent the my example
Best regards
Iskander
Message 20 of 22
(1,177 Views)
