I want to convert my large array-multiply logic into a faster called library, need some advice on the C code.
For measuring the timing I just had a simple flat sequence structure with 4 parts.
1) initialization stuff
2) high resolution timer
3) the code
4) 2nd high resolution timer
and I just run the code in continous mode and show the output of the subtraction of the two timers
Message 11 of 12
(734 Views)
One more small note, although it won't affect performance - when you wire an autoindexed array to a for loop, there's no need to also wire a value to the N terminal. The loop will iterate once per array element (if there are multiple arrays, or if N is wired, it uses the smallest number).
Message 12 of 12
(723 Views)
