I would like to know the documents of tomography.llb and witch algoritm is used
how may I use a series of bitmap as input of the program 'tomography.llb'
thanks for your attention.
luca iezzi
luca.iezzi@libero.it
(2,871 Views)
I am not familiar with tomography. Can you explain where to find this llb? Is it shipped with a toolset?
NI is in the business of making tools and not recreating existing algorithms. Chances are that there is nothing more than the standard CS algorithm going on behind the scenes.
Jeremy
(2,871 Views)
take a look at
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/5acad83a7bd2b93a8625696d004db6d5?OpenDocument
HTH,
Michael
(2,871 Views)
I did not even know that example was there. It is pretty neat. From what I can tell, the code takes the sum of the images in the intensity graph. Since the images are taken from a circle, all angles are equally represented. (You can press control-. to abort the VI)
Jeremy
(2,871 Views)
