IDE Performance decrease during "Work" 2025Q3
Dear community Members
I have installed LV2025Q3 since august. All worked fine for small pojects and short work.
As I use it now also for bigger projects and typically at least one the whole day I see significant perfomance decrease in the IDE.
Is this the "normal" behaviour of LV2025Q3 . I have never oberserved this in LV2025Q1 and ealier.
After closing the IDE and reopening the project it is again fine operatable but after a while of editing it becomes unaccaptable.
Thank you for some input on your observation.
Gernot Hanel
IONICON Analytik Gesellschaft m.b.H.
(1,319 Views)
I have not experienced this with LV2025Q3 but you could check and make sure that you dont have any memory leaks.
Joe.
"NOTHING IS EVER EASY"
(1,268 Views)
Something has changed with the IDE. I had a similar response when my code contained a pair of nested For loops where each for loop was parallelized. When both loops were parallelized the IDE grinded to a halt; I later found out the code complexity for that VI was around 26!
Look at you VIs using the property inspector,  https://www.vipm.io/package/abcdef_property_inspector_free/?utm_source=vipm_desktop
Check if there are any VIs with a large complied code complexity. Newer versions of LabVIEW seem to add complexity to parallel loops.
(1,259 Views)
Just to bring this topic to a kind of SOLUTION
I don't know the origin of my problem starting this thread but I just did my work.
After a while I probably changed some thing which solved the mentioned issue. Eventually it had to do with some nested loops but I can tell you the real origin.
Now this is fine and i have no longer a degrading IDE during development.
Thank you all for your input.
Gernot Hanel
(1,106 Views)
