IF statement in Formula Node
I have the following statement in a Formula Node in LabVEW 7.1:
if (x=1) y = 3; else y = 1;
When running the VI, whatever the value of X is, I obtain Y = 3 !!!!
Why ???
Tom
(3,691 Views)
Try x == 1 (instead of x = 1).
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,685 Views)
The formula node uses c-like constructs, so if you want to check for equality use " if (x==1) ..... "
With a single = sign in the 'test' it becomes an assignment. In C the expression (x=1) has the value of the right hand side of the assignment, here 1 (true) so the true part of the if will always execute. It's a common source of error in c programming.
I presume that this is part of a larger formula, ortherwise you should use native LabVIEW tests.
Rod.
(3,682 Views)
Thanks Becktho, thanks Rod !
(3,672 Views)
