INI tokens
From Darren's nuggets, he noted that you can increase the keyboard's responsiveness by setting QuickDrop Fast Search = True.  I am familar with INI format, but I do not know how I go about adding this token. Where is this file for adding this token?
Thanks in advance,
Paul
(4,050 Views)
Accepted by Paul_R.
C:\Program Files (x86)\National Instruments\LabVIEW 20xx\LabVIEW.ini
- James
Using LV 2012 on Windows 7 64 bit
(4,048 Views)
Or in XP it is C:\Program Files\National Instruments\LabVIEW 20XX\LabVIEW.ini
It is the ini file that is right next to the LabVIEW.exe in the folder of the version you want to use.
(4,039 Views)
