Icon bounds are no longer honored! (2015 bug?)
I think the only thing that's different is that I have "exclude dependent shared libraries" checked (under "additional exclusions").
Try the attached project instead
Message 21 of 26
(1,588 Views)
I'll have to try that tomorrow. I'll also make sure to try it on a VM with LabVIEW that has closer to default settings.
Message 22 of 26
(1,579 Views)
(Forgot to say: Your unmodified project seems to work fine here when building a source distribution)
Message 23 of 26
(1,562 Views)
I was able to reproduce what you have shown with the project attached.  When I unchecked "exclude dependent shared libraries" there was still white space which I did not expect.
Not sure exactly what the trigger is but almost certainly a bug and not a feature.
Message 24 of 26
(1,508 Views)
Yes, I noticed that too but it was late and I did not investigate further. 'Thought maybe I am seeing things. 😉
Could be a caching issues. Maybe a "right-click...clean" on the build specification would restore things.
In any case, please let us know if there is a CAR. Thanks!
Message 25 of 26
(1,487 Views)
It seems like CAR #515054 was already closed as fixed for this issue (found in LabVIEW 2014 and fixed for 2015).  I reopened the CAR and added the above .zip becuase it does not seem that the behavior was fully fixed.
Message 26 of 26
(1,408 Views)
