04-12-2008 06:27 AM
04-12-2008 10:46 AM
04-12-2008 12:11 PM
Hi Headtrip,
Could you post the vi with it saved exactly as you run it? With the vi I have from an earlier post, it looks as if the timeout is set to 10 seconds, and you are requesting to read 4096 bytes..... If this were the case I would expect that you would only see an update every 10 seconds, when the port timed out....
If the buffer is filling up, it would explain why you would eventually be seeing short streams.
I'll modify my state machine to account for the extra byte, and make it so you can easily change it back if the original spec is ok......
04-12-2008 02:08 PM
04-12-2008 03:31 PM
04-13-2008 06:05 PM
04-14-2008 12:24 PM
Hi Headtrip,
No Problem, just let us know if it ends up working for you, that's half the fun of helping! Even if it doesn't, let me know, perhaps we can "tweak" it.....
Howard
04-14-2008 04:21 PM
04-14-2008 05:58 PM
