Im New to LabVIEW. Is it possible to send signal to more than one plot on a chart using the value property node of the chart
Why are you using a property node? Did you first wire to the indicator so you get the correct value property? Why don't you attach your code?
Message 11 of 13
(799 Views)
Accepted by bwc1
Ive solved the problem by creating the graph first with multiple plots then creating the property node. This seems to work ok.
Thank you for you help
Message 12 of 13
(790 Views)
Which is why I asked if you did this before even creating the property node. As was already noted, the value property will change depending on the type of data you wire to the indicator. A value property should seldom be used instead of the terminal but if you must use one, you HAVE to first wire the terminal and then create the property node.
Message 13 of 13
(776 Views)
