Im a student having trouble with a Municipal Water Managment System Project......Help please !!!
True is the same as you posted, i was just trying to get this working before i started adding to it....I'm using LabVIEW 9.0
Message 21 of 77
(1,728 Views)
You are saying that it didn't work?  What I posted didn't work?
SInce you are using LabVIEW2009, you can simply drag the image I posted into the block diagram and you instantly get the code.  The image is called a code snippet.  You will need to use Internet Explorer in order to drag it as code onto your block diagram.  It does not work with firefox.  Otherwise, I can post the code.
You should see the 10 tanks fill up at a similar (but not the same) rate.  Once they reach 90% of fill, they automatically empty into the reservoir.  You can adjust the full value to something relativeto the volume that you want to model.
Let me know how it goes..
Message 22 of 77
(1,707 Views)
GASP Smiley Surprised  I shudder to think that Ray's posted code wouldn't work.  So I tried it myself and it does work fine.  My confidence in you  is restored, "mon cousin du nord".
To see it run faster(I don't have patience), change the delay time from 100 to 10.
- tbob
Inventor of the WORM Global
Message 23 of 77
(1,701 Views)
tbob....
What was that??  You thought that I'd post non-working code???!!!
okay... it did happen a couple of times...
 But the code was written after several bottles of wine... what did you expect?  😉
LOL!!
Message 24 of 77
(1,685 Views)
No no Ray, i didn't for one minute mean there was a problem with your code 🙂 just me being a dumb ass, dam volume levels of tanks!! All works and my 'plan' was to use the code as a subVI but now it cycles through once then stays filling tank 10 !! aahhhhhhh this project is driving me mad !! I wanted to try and add the C&F tanks here and have the reservoir pumping back to the 10 houses but ggrrrrrrrr these things are easy to say, no idea how to start, this would be easier to build in real life !!
Simone....
Message 25 of 77
(1,635 Views)
Two screen shots side by side there ^^^^^ 🙂
Message 26 of 77
(1,632 Views)
Using the reservoir as a lacal variable? Make any sense? Or will this just keep tracking levels and mean i cant set some sort of a trigger to pump from the reservoir when tanks get to like 20% full ?
Message 27 of 77
(1,611 Views)
You lost me with your last post..
Rule # 1   Never use Local Variables   😉
Dividing by 10 will give you the same amount in all 10 tanks.  So you could divide by 10 once and wire the result to all of the tanks.  I'm sure you don't want to do that.
Is the problem you are having related to using the code as a sub-vi?  I will look into that a bit later.  My "breaktime" is already over.  I need to wrap up some Boundary Scan software..
Message 28 of 77
(1,608 Views)
Local variables bad then i take it 🙂
Ya, not sure what i done but when i tried using as a sub-vi it got messed up...
Your right about that last post, doesn't make sense...don't mind me....(grasping at straws here 🙂 )
Message 29 of 77
(1,604 Views)
No problem.
I will look at the sub-vi aspect tomorrow morning.
Message 30 of 77
(1,569 Views)
