Image Flicker with USB IMAQ vision
Hi Randall
I've just finished to redraw my vi's.
Now all the flicker effect are totally removed, and
the video result, is exactly what i want to obtain.
Your Diagram, was almost perfect, the only impreciness
regard the frame differencing. In fact if you compare
the image difference module output result, you can
note that, in your case the moving object isn't evident
in the output, because the difference is performed,
among two equals frame, while, i want to compute the
difference among successive frame.
I've substantially modified the diagram. With some test,
i've noted that the canny filtering was totally useless
to the aim of better identify the object in the scene,
so i removed it. Moreover i've added a control to the
speed computing to compute speed only in the case that
there is only one object in the scene among successive
frame.
I'm attaching the finally .llb of my vi, if you want
view the final result
Well at last the work is finished, i thank you very
much for your support, thank to you i've learned a methodology
to draw ordered diagram in Labview. Thank you very much again.
Davide
Message 11 of 19
(2,847 Views)
Accepted by topic author Edivad
You still have some issues with your block diagram.  You have three USB Grab functions running each time through your while loop.  That means that you have to acquire three images before you cycle through the loop again.  That means your are only processing the motion detection algorithm every third frame.  You only need one USB Grab since you are only using one camera.  In the vi that I attached, I do not perform the difference on the same frame.  I use two image references and write the new frame to them in an alternate fashion.  Also, especially in a case like this, do not use local variables for your image references.  You cannot be sure if the data that is being read into your motion detection algorithm is previous data or new data (or a combination).  Besides, it is not needed for this application.
I use a shift register to keep the previous reference for the image subtraction (i.e. image0 is a new frame, subtract from image1, pass image0 through shift register, image1 is a new frame, subtract from image0, pass image1 through shift register, image0 is a new frame, subtract from image1, pass image0 through shift register, etc.....)
When I remove the edge detection vis from the vi I posted, my output looks the same as yours but with a faster frame rate.  Attached is one final version.
Randall Pursley
Message 12 of 19
(2,841 Views)
By the way, this is a very interesting application.
Randall Pursley
Message 13 of 19
(2,839 Views)
Great result, i'm seeing your vi and i must confirm your statement
sorry for my punctualization, i've derived some conclusion hastily.
For what concern my method for computing frame difference i can say
that i saw this methodology in an example, and i was very trustfull
to the correctness of the same. Your solution is surely more correct
and more performant. Now i'm going to analyze more carefully your
diagram
By the way, i've confirmed your
second-last post as a solution of my thread. Thank you for the
"very interesting application", this is a project that i've thinked
to develop for a subject at university.
Thank you very much for your interest
See you
Davide
Message 14 of 19
(2,825 Views)
Hi.
Is there any chance that you could send me this code for labview 8.5?
Thanks in advance.
Vinicius.
Message 15 of 19
(2,332 Views)
That thread is a couple years old so they may not still be around.  Save the file and post it to the downconvert thread and someone will get to it.
http://forums.ni.com/t5/LabVIEW/Downconvert-VI-Requests/td-p/1067229
Message 16 of 19
(2,329 Views)
Ok.
Thanks NIquist. I added the files there.
Message 17 of 19
(2,318 Views)
hello
we are doing a project on vehicle tracking using lab view
i have completed the following steps
1)color to grayscale conversion
2)threshilding
3)morphological operations
my problem is that how do i get a bounding box around the vehicle and track the vehicle?
please help.
an immediste reply would be of great help to us.
thank you
Message 18 of 19
(1,973 Views)
You are posting an unrelated question on an old, SOLVED thread.  If you want some response you should start your own new thread so that it will be noticed.
Message 19 of 19
(1,960 Views)
