Image processing
I could not figure out what exactly is wrong in this program. It should suppose to yield image with edges detected but only blank output appears.Please can someone help me/
Thank you.
montu
Message 1 of 15
(8,317 Views)
Accepted by montu.dada
I think it would help if you provided a sample input image.
http://www.medicollector.com
Message 2 of 15
(8,311 Views)
try to use 24-bit pixmap on the output of Unflatten Pixmpap.vi instead of 8-bit pixmap. On my PC it works.
Simyfren
Message 3 of 15
(8,310 Views)
Hi mate,
  There isn't choice for 24bit . but only for 1, 4 and 8. Can you please attach your working VI.
Thank you.
Message 4 of 15
(8,301 Views)
 This was the image i used. cute!! 🙂
Message 5 of 15
(8,299 Views)
Here it is. Which version of LabVIEW do you have? I have 13.0.
Simyfren
Message 6 of 15
(8,297 Views)
I am using labview 2011 so this does not open 😕
montu.
Message 7 of 15
(8,293 Views)
And there is a outpu from VI which I attached.
Simyfren
Message 8 of 15
(8,292 Views)
Here is the same VI saved for 2010 version.
Hope this works now.
Simyfren
Message 9 of 15
(8,291 Views)
 still the same error. file ver is new (12) than in my system (11).
Can you please save for 2011.
thank you
Message 10 of 15
(8,286 Views)
