Hello. I'm trying to save some image from the Front Panal but i don't like the resolution of these figure. In MATLAB, for example, I can export the image considering 600 dpi and so the quality of the images are so good. I would like to do the same in LabVIEW. Is it possibile? How can I export some images with good resolution?
Thank to all!
(3,991 Views)
If you don't like it, have you tried just getting a high res monitor and doing an old fashioned screengrab with paint?
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(3,985 Views)
Dear James for the moment I've tried to do stamp an paste in Paint as you suggested now. I don' like this figure. Is there another way to extract figure in LabVIEW?
(3,979 Views)
Accepted by Mark87
I kind of assumed you were using thisgraphics.png techinque from your original post Mark!
James
(3,956 Views)
Dear James, Can I have your good VI? I don't know some functions. Is it a problem for you do send me the VI?
(3,947 Views)
Hi Mark,
if you are using LV2012 or above, download the png and drag onto you block diagram to get the snippet!! (or find the items on the tools palette where I have told you each on is in the comments above each function) - it helps to learn where the bits came from!
James
(3,935 Views)
James you are right. I have done it and it's ok. Sorry for my request! 😄
All the best! 😄
(3,926 Views)
