Importing data from .tdms file and comparing with measured .tdms file
Greetings,
I want to make an application that writes measured values to a .tdms file.
But I want to make a seperate database in a .tdms file which contains the theoretical values.
After the measuring the application should compare the measured values with the theoretical.
So the application should read just one cell of the .tdms file.
Is this possible?
(2,791 Views)
Yes
Have ou had a look at the examples that come with LabVIEW? There are several examples about how to use TDMS files.
Help >> Find examples... >> type "TDMS" in the Search tab.
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,779 Views)
Accepted by Innervision
(2,761 Views)
