Importing gvi from other project into Web Application Project in NXG Web Module 5.0
Is there a way to import previously written gvi, libraries, etc. from other NXG projects into a Web Application Project? Or is there a way to make a regular project into a web application project?
I am using NXG 5.0 and Web Module 5.0, but I cannot find a way to convert a gvi into gviweb or include a web application into an existing project.
I know that I can link files by selecting Add Files, but I am not sure if this is sufficient when I want to include it as a subVI for the WebVI and building it as a web page.
(3,063 Views)
Yes, how do you include a dependency?  Is the only way to make the dependency an add on?
Bill
CLD
(Mid-Level minion.)
(3,027 Views)
Accepted by topic author pipipi0405
I self-resolved this issue by adding a new Web Server in System Designer and adding an Application. Then I was able to specify Web Server to add a gcomp for WebVI.
(2,993 Views)
Hi pipipi0405,
If possible could you upload a few screenshots of how you managed to achieve this.
(2,718 Views)
Could you please describe what you have done a bit more in detail? It is not so Easy to understand.
(1,863 Views)
