 pipipi0405
			pipipi0405
			06-15-2020 11:10 PM
Is there a way to import previously written gvi, libraries, etc. from other NXG projects into a Web Application Project? Or is there a way to make a regular project into a web application project?
I am using NXG 5.0 and Web Module 5.0, but I cannot find a way to convert a gvi into gviweb or include a web application into an existing project.
I know that I can link files by selecting Add Files, but I am not sure if this is sufficient when I want to include it as a subVI for the WebVI and building it as a web page.
Solved! Go to Solution.
 billko
			billko
			06-16-2020 06:21 AM - edited 06-16-2020 06:22 AM
Yes, how do you include a dependency? Is the only way to make the dependency an add on?
06-16-2020 11:21 PM - edited 06-16-2020 11:22 PM
I self-resolved this issue by adding a new Web Server in System Designer and adding an Application. Then I was able to specify Web Server to add a gcomp for WebVI.
 KKINTER
			KKINTER
			11-13-2020 05:22 PM
Hi pipipi0405,
If possible could you upload a few screenshots of how you managed to achieve this.
 Svein-Tore
			Svein-Tore
			07-02-2022 09:29 AM - edited 07-02-2022 09:29 AM
Could you please describe what you have done a bit more in detail? It is not so Easy to understand.
