In Example Finder, I can't open the example, error: server not running
It say's the web server is not running when I try to click into any examples. It's installed under academic license 12.0.1.f3
(3,570 Views)
Most likely this is occurring because of the Service Locator (part of the System Web Server) is not started. Refer to the following KB for more information and solution.
http://digital.ni.com/public.nsf/allkb/2F55B93405ED07AA862574A300826580?OpenDocument
Let me know if this solves the issue or not.
Kind regards,
Rik Prins, CLA, CLED
Software Development Engineer
(3,553 Views)
The solution to stop and start the NI service locator didn't work.
The coming one to add the paths as execeptions, where to do so?
I have tried to add it as shown in the attached image but I couldn't find them in the list. Maybe I went to the wrong place? Can you give me more guidance on this?
(3,543 Views)
Does this issue only occur when you are logged on to the Domain? In other words, if you donot log on to the network does the example finder work correctly then? If so then you probably have to ask your System Administrator to allow access for the NI System Web server in your Firewall.
A good resource for finding out what ports should be opened in the Firewaal to have NI SW work correctly is:
http://digital.ni.com/public.nsf/allkb/CEF5A3568A5DA71D8625732800520EA1?OpenDocument
(3,536 Views)
