Index Array always returns zero when reading from 3D Array
I have 3D array diamension as a 9x2000x5 array.  I have this array filled with data and when I attempt to read a single data point out of the array the Index Array function always reads zero. I have place a probe on the input 3D array and when I set the probe indexes to the same data point the probe shows the value stored in the array. I also have an indicator displaying the 3D array data and it shows data in all the locations. For example if I attempt to read location 0, 144,0 in the 3D array it alway returns zero. Yet I know the value in that element is 6.8616E-5. Every element I attempt to retreave from the array yields zero.
Has anyone seen the Index Array exhibit this kind of behavior?
(4,119 Views)
No, and that's not likely to be the source of the problem. Without actually having a VI in hand, I'd guess the problem is with the indicator that displays the element you're retrieving. If I had to guess, you probably have the wrong representation for the indicator (like an integer instead of a float), or you have the digits of precision too low.
If you attach your VI we can provide a more definitive answer.
(4,104 Views)
here is an example of indexing from a 3D array:
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(4,092 Views)
Accepted by johnfr
Issue resolved. As usual it was pilot error on my part. Had the row and column lines reversed.
(4,053 Views)
