Install Xilinx compilation tools
Hi, I was trying to use IP block and i received the message that Xilinx Compilation Tools are not installed. How can I install them?
Cheers
Loop3r_III
(2,760 Views)
Hi Loop3r,
Install the LabVIEW-FPGA module…
(2,733 Views)
Hi thank you for the answer, I have already installed LabVIEW FPGA module before I asked the question.
(2,731 Views)
Hi Looper,
You didn't say so before…
Which OS are you running on?
Did you get any warnings/error messages while installation of the Xilinx tools?
Which Xilinx tools did you install?
(You know: provide all important information which is needed to answer your questions and help with your problem…)
(2,725 Views)
I am sorry.
I run windows 10 and I have not installed Xilinx Tools. Are Xilinx Tools normally installed during LabVIEW-FPGA installation?
When I try to use my computer as compiling server I see this warning. I don't know what are and how to find the installation media.
Also when I try to configure IP block I see this message
(2,717 Views)
Hi Looper,
So there are no tools installed, but you wonder about "missing software" messages?
Those Xilinx tools are usually installed with the LabVIEW-FPGA module!
When the Xilinx tools aren't available on your computer then how should it act as compile server? The Xilinx tools are needed for compilation of FPGA code!
@Loop3r_III wrote:
II don't know what are and how to find the installation media.
You should got some installation media when you installed LabVIEW! (Some years ago you got diskettes, CD-ROMs, DVDs, and USB drives. You still can get USB drives on request.)
When you use LV2017 you could download the neccessary software from NI website. I guess you have an active SSP license!?
Btw. why don't you use the Compile Farm service by NI to compile your FPGA code?
(2,711 Views)
