Integer Number ( Help )!!!!
Hello
I need help from one of you guys which is how can I do a LED light works when I use integer numbers like ( 1, or any integer value  ), and turns off when I use non-integer numbers like ( 0.6, or any non-integer value )
Thank for any help...
Message 1 of 8
(5,162 Views)
Compare the number to the rounded version of itself.
Message 2 of 8
(5,159 Views)
Sounds a lot like this topic.  Is this the same calculator?
Bill
CLD
(Mid-Level minion.)
Message 3 of 8
(5,143 Views)
Thank you so much for every one who is trying to help me, but I am new in using this programe this is why I hope from u to give me more explanation,,,,
I use labview 2014
Message 4 of 8
(5,134 Views)
I do not think so
Message 5 of 8
(5,132 Views)
Is the number equal to the number when you round it to the nearest integer.  Yes?  It must be an integer.  No?  It must not be an integer.
Message 6 of 8
(5,116 Views)
hi,
1. Divide your number by 1, use 'Quotient & Remainder' function.
2. If the remainder = 0 then LED is ON otherwise OFF.
Note: Change the data entry if you want it only for positive numbers
Amit
CLAD
Message 7 of 8
(5,070 Views)
Of course all this only works well if the number is not derived from a calculation involving fractions. For example, the following will deny that 1 (e.g. 10x0.1) is an integer.
You need to be careful!
Message 8 of 8
(5,061 Views)
