Interesting Modbus Library Behavior with RS-485 RTU Serial
Your VI runs Ok on my device.
I started to change your VI and I got an error after 200-500 loops.
The error occurred in the Write VI but not a time out. See screenshot.
Working on my computer with other things the fault disappeared !?!? (no error after 5000 loops)
Just to get more info, can you try the modified VI ?
I saved it in LV 2020 I believe that is the version you are using. Changed the default values.
Kees
<EDIT>
Same error after 15377 loops.
Message 21 of 32
(1,308 Views)
That's some fun loop work you did to clean some of that mess up. The array'ing and indexing is a cleaner way for sure.
Will be testing today on the desk with it. Just downloaded it.
Message 22 of 32
(1,298 Views)
Some quick testing after I changed the parity back to Even. Saw you had it at None. My devices needed it at Even.
***Edit - I'll spy on these lines as well with the logic analyzer and redo.
Message 23 of 32
(1,292 Views)
Timeout on Read 16 Registers from Device 01
Good Read 16 Registers from Device 01
Timeout on Read 16 Registers from Device 05
Good Read 16 Registers from Device 05
Assuming the error behavior is standard LV, an error on a read would prevent the rest of the VI from executing. If that's correct, what's interesting is that my physical trace record using the logic analyzer never records a response to that read request. Either the end device misses it or the request is malformed?
Message 24 of 32
(1,268 Views)
It kept me thinking and I worked further on it. Also because we use ModBus and multiple slaves already for a very long time.
I don't use the MB lib. We have dedicated MB commands and I started with MB and LV before the lib was available.
There are some MB timing rules that that are important. Most of them are from the time that low baudrate were used.
But with todays (fast) computers it could be too fast.
Important is the time between two MB messages. It depends on the baudrate. At 9600 baud and above it is a few msec.
If I remove the delays in my VI's I also get a time-out error sometimes (after 10k-50k loops)
The delay must be at least 3.5 character time long.
If two MB messages are sent directly after each other a slave will see this as one command if there is not enough time between the two commands. This results in a wrong command with an incorrect CRC. The slave will ignore this message.
In my VI's this delay time is fixed to 5 msec. Low baud rates are not used anymore.
I added my VI's to your VI. Can you try this one?
Kees
Message 25 of 32
(1,256 Views)
Absolutely will do so. Apologies on missing this until today.
Message 26 of 32
(1,219 Views)
I'd say unequivocally that your library does better than LV's and also that I might have a device issue as well. I tested your library at a various amount of delays as well as the LV one reading the same registers, same wiring, same adapter, etc.
Next step would be to load into the cRio and use the hardware RS485 rather than the usb converter I have been testing on the desktop computer. Might get more deterministic behavior on the rio?
Library KC KC KC KC KC KC LV LV
ms Delay 0 1 2 3 5 10 0 2
1 0 58 637 246 719 31 210 33
2 65 496 719 1177 26 76 111 41
3 0 668 1124 1118 18 18 81 618
4 8 10 3135 1425 474 8 121 21
5 43 213 484 767 42 8 904 37
6 52 15 476 649 710 90 380 130
7 8 874 785 973 194 100 290 61
8 114 535 5648 169 734 0 71 0
9 5 220 1395 352 600 22 1204 396
10 0 640 770 159 7 13 24 326
Average 30 373 1517 704 352 37 340 166
Message 27 of 32
(1,204 Views)
Even better results on the rio.
Up to 11K using the 2ms delay. I assume it will fail overnight, but this indicates to me there is something way better about how KC's library does the timing vs how the LV library does them.
Of the 4 runs thus far on the rio, I have 4072, 5008, 16567 and over 4K now.
Message 28 of 32
(1,199 Views)
Still think the KC library is better than the LV included. 38400 also better than 19200 at least with 2ms delays.
Library KC KC KC KC KC KC LV LV KC - cRIO LV - cRIO KC - cRIO LV - cRIO
Baud 38400 38400 38400 38400 38400 38400 38400 38400 38400 38400 19200 19200
ms Delay 0 1 2 3 5 10 0 2 2 2 2 2
1 0 58 637 246 719 31 210 33 4072 109 1996 36
2 65 496 719 1177 26 76 111 41 5008 121 466 124
3 0 668 1124 1118 18 18 81 618 16567 188 319 299
4 8 10 3135 1425 474 8 121 21 8044 41 142 102
5 43 213 484 767 42 8 904 37 6319 201 617 45
6 52 15 476 649 710 90 380 130 15396 75 261 186
7 8 874 785 973 194 100 290 61 4067 37 144 35
8 114 535 5648 169 734 0 71 0 8921 44 526 92
9 5 220 1395 352 600 22 1204 396 666 162 826 143
10 0 640 770 159 7 13 24 326 13543 185 237 244
Average 30 373 1517 704 352 37 340 166 8260 116 553 131
Message 29 of 32
(1,166 Views)
Still doesn't look good. The delay of 2 msec. or more should be enough. It is clear that there is something wrong. It should work without any errors.
Did you try a long delay, let say 10 msec. ? This because the result gets better with a higher baud rate.
I will think about it further, but for now I am out of options......😕
Kees
Message 30 of 32
(1,154 Views)
